Hi All,
well, doing super-telephoto-shots with a DSLR has always been a difficult job.
Super telephoto lenses are very expensive, heavy and unhandy. The wider their maximum aperture is, the heavier and more expensive they become.
However, although it is technically difficult, you can do highly interesting things with such lenses.
This robin I got this springtime with a 35 year old VIVITAR 400mm / 5.6 lens fitted to my SD14.
Forget about tripods ... there is no chance to adjust it ... such birds do not let you enogh time to adjust it precisely ... you have to do it freehended.
Two main problems meet here ... blurring your shot ... and having your focus adjusted precisely. In this case I had to focus manually ... sure, the VIVITAR has no AF technology.
You do need good light for supertelephoto shots. A dimly lit scene will force you to use a tripod since fast shutter speeds cannot be realized.
As shutter speeds become longer ... you even will have to use the mirror lockup setting of your SLR ... otherwise the mirror stroke of your camera will blur your photo.
Working outdoor also might become tricky .... a slight breath of wind can be too much movement at your tripod to blur your photo.
Well, some months ago, I got my SIGMA 80-400mm EX OS which made freehand shots much more comfortable and easier. The OS works like a dream ... SIGMA do not tell stories, claiming that the OS brings about two up to three shutter speed standard-values.
What about combining the 80-400mm OS with a 2X- tele extender?! ....
Well, 800mm shots are a very extreme thing to do ... but ... there are occasions which really demand such astronomic focal lengthes.
The robin was pure luck to be managed with just 400mm! You have to approach it to less than 12 feet.
The SIGMA 2X tele extender "darkens" each lens it is used with. The loss of light is two aperture values.
Used with the 80-400mm / 5.6 you so get a 160-800mm / 11.
Normally much too dark to work freehanded ... but in combination with the OS ... let us have a look!
To give you an impression, what 800mm (freehanded!) look like .... a simple comparism first.
28mm:
800mm:
Absolutely unbelievable .... I managed the 800mm shot (i.e. 1360mm ff view!) with 1/50s shutter speed. This does not work always -certainly- but sometimes you are lucky!
The AF-system is deactivated with this lens! So I had to focus manually. SIGMA has a list on their page, which lenses support the AF in combination with the converter and which one do not!
Image quality .....:
Well, The 80-400mm is a fine lens as far as image quality is concerned.
The extender drops it slightly ... ! Image results then remain amazingly acceptable.
Some further test shots .....
Unfortunately, the extender is not mine ... SIGMA Germany made it available to C-Info's SIGMA MODs. So I have to return it ... :uhoh:
Anyway ... I can imagine to buy one myself ....
28mm:
800mm:
