Clicks on fstop ring for 50mm 18 FZuiko
marosari00
Hello!
Having bought my first manual Olympus lens, need to know if the f-stop ring has click stops. The 50mm 1.8 f-stop ring does not have any.
Thanks!
Manuel
Manual:
All of my Olympus OM system lenses have detent stops. You will feel them more than hear them. However, the OM system allows you to shoot anywhere in between apertures.
Regards and Good Shooting:
Gilbert
>If your 50 mm 1.8 f-stop ring doesn't have detents (clicks) it is not >working right. It is possible to open the front of the lens and clean out >the hardened grease and replace it with new grease so the little ball >bearing works correctly. Be very careful and work over a cookie pan so >you don't lose the spring or bearing.
There is more to this and the complete directions should be available on the web.
Gregg
