G1 WITH THE ZEISS 35 PLANAR
I am new to the board (compliments on some really imformative posts)...
I have a G1 which I bought used with a 45 Planar and am considering buying a 35 Planar or 28 Biogen. In my readings I understand that some early G1 bodies need to be modified (software?) by the factory to use these lenses on autofocus.
How can I determine if my body needs this upgrade? The former owner had both a 28 and 35, does this imply that the body was of a later version and will work?
The serial number is 096013.
Dave
> If you have a green label inside the camera where the cassette goes you won't need the upgrade.
