Zeiss Ikon 5015
admin1
Administrator
Chi Yuan Joseph was the first here, who posted the link. I add the PDF here directly, in case the pdf will be removed later on on the Zeiss page
<center><table border=1><tr><td>
(105.2 k)</td></tr></table></center>
dirk
DPRF-Founder
Administrator
Here the text of The Zeiss page and some images:
The powerful photojournalist – fast, compact, accurate
The C Sonnar T* 1.5/50 ZM lens is the modern technological reincarnation of the classical Sonnar 1.5/50, the fastest standard lens of its time, for the Contax II rangefinder camera.
It is fast, very resistant to flaring and unusually compact – therefore the “C” in the lens name. With its well controlled distortion, the lens produces a very accurate representation of objects. It can take the same filters which fit the ZM wide angle lenses with 28, 25 and 21mm focal lengths. This is a very versatile lens for photojournalistic work in general and for available light photography in particular.
Technical Specifications
Focal length: 50 mm
Aperture range: f /1.5 – f/16 (1/3 f-stop)
No. of elements/groups: 6/4
Focusing range: 0.9 m – infinity
Image ratio at close range: 1:15
Coverage at close range: 37 x 55 cm
Angular field, diag./horiz.: 46°/38°
Filter: M 46 x 0.75
Weight: 250 g
Dimensions: ø 56 mm, length 45 mm
careljon
Hi everybody,
Strange that ZEISS is referring to the CONTAX II, because the SONNAR = 1.5 lens ("black") was already delivered for the the CONTAX "I" (not = marked as such!) rangefinder camera in the early 19-thirties !
Careljon
