ARTIXSCAN F1 FIRST IMPRESSIONS
jotloob
DPRF-Patron Gold
I got my new scanner just two days ago . ARTIXSCAN F1 .
The scanner is very well packed and all accessories are supplied . No parts missing .
Unpacking has to be done very careful , as the scanner is in a slippery plastic bag .
My predecessor scanner was an ARTIXSCAN 1800F . The F1 is of almost the same housing design and also size . The film holders are of a new design . Glasless film holding , but its a bit tricky and you have to get used to that .
The 35mm film holder takes 4 stripes of film and the slide holder can take 12 framed slides .
The 120 film holder just takes one stripe of film , for the sizes 4,5x6 , 6x6 , 6x9 , 6x12 or even 6x17 . This holder is a real advantage in comparison to the 1800F .
Before you switch on the scanner , you have to unlock the transport safety screw and install the scanner software .
Unlocking the screw turned out to be not so easy . You have to turn the screw counterclockwise and then the screw should push out for about 12mm , which did not happen . Even not after many times turning the screw forward and backwards .
This issue solved itself next day , after the scanner was up to decent room temperature .
Installing software .
You can either install MICROTEK SCAN WIZARD PRO or SILVERFAST Ai STUDIO .
These two packages came with my scanner .
I prefer the SILVERFAST Ai STUDIO .
I am using MAC OSX 10.5.1 LEOPARD . That operating system did not make any attempts to install SILVERFAST .
So what you have to do , visit the SILVERFAST WEB-PAGES and register with the serialnumber of your software . Then you can download the version which is then recognized by LEOPARD . NO plug and play .
After power on , the scanner does do something , but you dont know what . At least you can hear some funny "noise" of different frequences . A bit later , your software tells you , that the scanner is initializing . O.K. Have a beer in the meantime .
Finally , the scanner came to a rest and , I found a hint in the very poor documentation , that this was the warmup and initializing phase .
Next step is : color calibration . The SILVERFAST IT8 calibration .
You have to insert the little color target film piece into the 120 holder . IMO , this little piece of film is too small , but I managed .
You then need to click on the color calibration icon in SILVERFAST and the calibration works fully automatic from now on . A good thing . When the calibration is finished the icon turns into a colored icon to reflect , the calibration is performed .
For my first scans I took two 4x5 color slides , KODAK EPN .
It is adviseable to download some of the handbook information from the SF homepage .
SF is quite easy to understand and all parameters are easy to set .
I choose an outputsize of 40x50 cm at a resolution of 360dpi . Hitting the control button at your keyboard now shows you the scanresolution . This resolution is automatically calculated depending on your choosen output size , which in my case was 4800 ppi and that gave me a file of 208 MB .
You need patience , because that scan took about 5 minutes to come to the end .
As I said , nothing for people in a hurry .
I have done some more scans in the meantime .
As far as I can see up to now , the quality of the scans is superb .
Now , this was no fairy tale , but my first experience with the F1 .
Images to show the resolution , as good as it can be here on the net , will follow .
Jürgen
Thanks Jurgen, that was fast.
However, the math doesn't do it for me. Did you mean a 35mm color slide or a 4X5inch sheet film?
A 4800 dpi scan of a 4X5" would generate a 360 dpi print of 53X66 inches, and you're talking about a 40X50cm. print.
The pick looks good. Could you please post 100% crops?
Thank you much
Eduardo
Eduardo
Obviously there seems to be a lousy bug .
Let me check and I will come back , with what I found .
Jürgen
Eduardo
The bug is the crops .
The original transparency is a 4x5 inch sheetfilm . The exposed image has a size
of 9,1x11,6 cm . This is the WYSIWYG size of the SCHNEIDER 4x5 inch HIGH END VACUUM BACK .
Now , if I choose an output size of 40x50.1 cm (proportions are the same) that image is scanned using a 1600ppi resolution which results in a file of 232,8MB .
If you choose an output size of 41x52,4 cm (just trying to see where the resolution goes up to the next higher value) , that image is scanned with 2400ppi and gives a file of 247MB .
Using an output size of 61x77,9cm , it is scanned with 4800ppi and gives a file of 556MB .
Scanned with 48bit RGB (3x16bit) . Used colorspace is LSTAR-RGB-V2.icc
Following is a "cropped scan" of 5,1x10,2cm to the output size of 30x60cm .
It is scanned with 2400ppi and results in file of 206MB .USM is 120% at 1,5bits .
The image turns out to be crisp sharp , when printed , or as Colin would say , as sharp as a
fisherman's wife .
You won't see the sharpness in this jpeg image . I might do something wrong here .
If so , just let me know , what .
For Bavarian train fans , this engine is called the "sugar baby" , because it was often used as a shunting machine in a sugar factory .
Jürgen
Thanks Jurgen.
Could you please scan 120 neg film and show us 100% crops? Are you familiar with the Epson flatbed line? If so, what would you say about comparing them to the Microtek?
Beautifuly sharp pic of the train. This pic has the film quality that digital lacks: Sharp but gentle at the same time. Digital usually gets a little harsh even when carefully sharpenned. Sorry I'm lost, is that a museum train or a model?
Eduardo
Eduardo
It is a 0-gauge model train made by FULGUREX and there were only 150 pieces handmade .
I do not have any experience with EPSON scanners at all .
But I will do test scans of HASSELBLAD slides later this week . 100% crops .
Jürgen
Damn, that is one fine piece of work!
Paul: Stop laughing
Jurgen:I will be expecting for your Hassies tranies
Eduardo
