Berlin
Guest .
Banned
Hi All,
Silly enogh, I never happened to visit Berlin before. Well, Berlin has its certain history. Since I am a born West-German, visiting Berlin (the former devided city) used to be difficult when I was young.
Now, that the German unification took place 19 years ago, Berlin is available like any other German city ... no excuse therefore that I did not manage to go there before ... well now I did so! :)
Not necessary to mention that all Photos are done with SIGMA (SD9/14)
Due to SIGMA OS ... I did not need a tripod at all.
Some impressions......
... to be continued ...
Thank you, but it was Nue Ulm.....but I was close....
Very nice pictures Klaus.....Out of all of them I like #3 from the first batch with the fountains and clouds.....I love clouds....
Which lenses did you use..and did you use any special settings..??
Tony C.
Hello, Klaus!
Once again, your pictures tell the story of a very dedicated photographer who is fortunate enough to be using Foveon technology to portray his talents. You certainly like perfection and use to advantage the light you discover.
It's almost like accompanying you on your many trips. Thanks, Klaus.
Sincere regards, Jim Roelofs
Hi all,
thanks for all your comments. :)
My equipment "on tours" .....
Well, like many fanatics I am a collector, as far as photo equipmewnt is concerned. At home, I have quite a shelf filled up with cameras and lenses.
Indeed, the most difficult question is, what to carry with you on tours?!!
Two thoughts on the issue:
1) Nothing is more annoying, than to see a scene, without having the right photo equipment at hands! Maybe, therefore I still hesitate with the DP1 (a brilliant camera I had for testing!!).
2) Unfortunately, you simply cannot have all your odds and ends with you ... you want to be mobile and no snail un tours.
Finally, you have to think about a compromise .... well ... mine might be extreme ... I cannot do differently! :eek: My compromise comes to more than 20 British pounds.
Bodies with lenses (always mouinted to have it with a single grip)
SD14 / SIGMA 18-200mm DC OS (3.5-6.3)
SD9 / SIGMA 10-20mm EX DC (4.0-5.6)
Furter Lenses:
SIGMA 28-80mm HF (MACRO)
SIGMA 28-105mm (2.8-4.0)
SIGMA 80-400mm EX OS (4.5-5.6)
VIVITAR 50mm / 1.9 (M42-Mount for Portrait usage)
Flashlights:
Metz 34-CS-2 (a very small and light flashlight that can do really small distances (very useful at macro situations!)
SOLIGOR AR-30-T Ringflash (ideal with the 28-80 HF MACRO)
Other equipment:
automatic bellows LOOK HERE
reflex viewfinder
accumulators (NP-400 (SD14) / AA (SD9) / CR-123-A (SD9)) LOOK HERE
remote releasers (cord and cordless)
emory cards
M42/SIGMA SA mount
extended flash rail (for macro usage) LOOK HERE
I did not forget to mention a tripod in my list. There simply is none! Even the nightshots above are done freehanded ... SIGMA Optical Stabilizing makes that possible. :)
