Years ago I couldn't find an aftermarket remote-release cable to connect my Contax to a flashlight release button. The flashlight used a plug as for the headphones on a walkman.
So I had the idea: I cutted my Contax cable switch L30 in the middle of the cable and fitted chinch-connectors on the ends. I also made a cable with a chinch connector and the plug for the flashlight.
If you do so, you can also fit extension cables with those chinch connectors to your cable switch. This will be less expensive and more flexible than to buy all those three different cable switches from Contax.
Matthias
Matthias
