Calibration seems to not make a big difference?
flycaster
I've been re-calibrating my monitor (Asus PA278QV) for different times of the day with the XCalibrating seems to not make a big difference-Rite i1Display Studio. After having accumulated several calibrations, I have noticed two things:
1. At the end of calibrating, one can look at before and after test images. When doing so, I only noticed very, very, slight differences with each before/after for each time of day
2. When taking an image that had been previously processed (same monitor calibrated earlier with same device) before I started with the new re-calibration, I again noticed that my various different times of the day calibrations only made very slight differences in the test image.
All in all, the colors seemed to remain the same throughout the range of different calibrations, whereas there appeared to be very slight brightness changes. So far, using the device claibration set to 100cd and sRGB and the Windows 11 profile sRGB IEC61966-2.1 look to be pretty much the same. Would this mean that I might as well forget about my calibrating and use Windows sRGB?
It may simply be that your eyes are autocorrecting the color you’re seeing.
Or it could be that my color sense is not so good. Which, as a hobbyist, is quite possible.
Rather than "calibrating for different times of the day" it's more productive to standardize the environment around your display. This means closing any window shades/curtains and having the same houselights on and moderately bright when editing.
Calibrating simply means putting a device into a known condition. The profile defines the hues/gamut of that condition. It does not affect the environment nor the observer - factors which also affect color.
Thanks for the advice.
