<I suspect a linear polarizer will be satisfactory with this camera, but I would like to confirm it. Does anyone know the authoritative answer, or perhaps can someone suggest a conclusive way of testing?>
A very simple one-minute test can be performed right at the photography store:
1. Attach the linear polarizer to the lens.
2. Switch your camera to the spot-metering mode.
3. Direct the lens at a non-glossy surface (a brick wall, a sheet of paper, or alike).
4. Adjust the aperture, so that the shutter speed reading should be in the middle of the range or higher.
5. Watching the shutter speed reading rotate the rim of the linear polarizer.
If the reading remains the same (or it is changing 1/2 or 1 step in the case the surface you direct the lens at is nevertheless glossy), your camera will perfectly work with a linear polarizer.
If the reading is changing dramatically while you are rotating the rim – from the normal to no light at all – your spotmeter requires a circular polarizer.
You can do a similar procedure to check whether your autofocus works with a linear polarizer or not.
Finally a few notes:
1. I know from experience Contax ST does not need a CPL, though it has a spotmeter.
2. The official www.contaxcameras site says the G2 does not need a CPL either. Pay your attention to the fact that the G2 features both spot-metering and combined passive+active autofocus.
Andre Shipoff
Andre Shipoff
