photostranger
On another post (RX v. RXII) my math was questioned about f-stops. I've been using manual exposure systems for a long time, you'd think I'd have no question what so ever, but I find myself second guessing myself. It's not 100% necissary, i get good exposures, but it deals with weather or not 1-stop can be expressed as 100% more light. Here is the original post, which i had over-complicated greatly:
John- you are likely right, I have spent more time in the digital darkroom than out shooting. I am a digital media major that is about to switch to photography.
However, I could have sworn that 1 stop increase doubles the amount of light on the film. This is evident when you stop down and require a twice as long exposure.
If each stop down DOES cut the light in half, then each stop up DOUBLES the amount of light, right?
If this is correct, then:
f5.6=+0% differential (1:1)
f4.5=+50% differential (1.5:1)
f4.0=+100% differential (2:1, twice as much total light)
f2.8=+200% differential (4:1)
Ratios are expressed as "light on film plane:light available"
If you take a value of 50 and increase it by 25% (more light) then the result is 62.5 ((50x0.25)+50) or calculated from ratio and simplified (50x1.25). If "62.5" expresses the luminance on the focussing screen this would not be 1/2 stop, a value of 75 would be (50x1.5) and a value of 100 (50x2) would be one stop as 1 stop expresses twice as much light entering the film plane. This is assuming my ratios and factors are correct.
As a value of 50 would already be present (light available), the additional differentiated(sp) value would be added, resulting in the values 62.5 (12.5+50), 75 (25+50) and 100 (50+50).
In the case of a 25% or 1/4 stop increase (based on that 100%=2:1), would result in a +12.5 differential, as, 12.5 is 1/4 of 50 (50x0.25=12.5). A 25% increase could be expressed as 1.25:1.
So unless i'm TOTALLY off, which is entirely possible, 20% would be slightly less than 1/4 stop?
