psmith2383
- Joined
- Jun 25, 2008
- Messages
- 16
Not a great problem but the silver round "Contax" plate has become loose from plastic body. The glue seems like rubber cement in that it doesn't really dry. Had unit for two years. Is this the way the cap was made or did the previous owner add the rubber-type cement? Any suggestion what I should use in re-gluing this critter. Must be very careful not to glue movable parts under silver plate that you press to lock cap on lens. Phil
