Long eхposure shots emulation. Pentax K-1 / K-1 Mark II
Serge
About 8 years ago I forgot to take ND Lee filters with me. When I got to the location, I decided to use the Pentax K-1's built-in feature - Interval Composite. This is the process of stitching together several frames to create a single image. You can get a great result by stitching together from 15 frames at intervals of one second. You can also use more frames. See examples below...
Interesting Serge. You know many of us... (ok, me)... use the camera as a basic tool. Maybe I'll bracket exposures a bit.
But your images here, in addition to looking beautiful, show us... (ok, me)... that the tool we're using is more complex with features that are not obvious at first. Anyway, good post. Thanks.
Yep, used it before but I had some issues (I can't remember) so I stick to using ND filters (ND10 and ND12) for long exposures. What I do find this feature useful for is noise reduction at high ISO but I prefer to do the averaging on the computer in post.
That’s very impressive Serge. Wish I had that patience and skill.
Thanks for the kind comments!!!
BTW...
This method has a few drawbacks, so it is still better to use high quality ND filters.
1. When someone looks at the Exif, they will see a mismatch. The image will look like a long exposure photo, but the shutter speed value will not.
2. The shutter speed will be much slower than with ND filters (there are intervals between shots and there can be many shots). This means, that small moving objects are "more critical" when shooting this way. So not everything can be shot like that.
But there are some advantages.
1. When you stitch shots together, you improve the clarity of the shot and this dramatically reduces the amount of overexposed areas (for example, highlights on the surface of the water from the sun).
2. If the weather conditions are not favourable (rain, fog, splashing water, etc.), you can save on expensive ND filters.
3. By using this method, it is possible to reproduce very long exposures without the degradation of colour that is possible with "strong" ND filters.
4. "Backup" method when no ND filter is available
Further examples. The Solovetsky Islands, White Sea. (15-20 frames stitched in one image)
The top image was taken at 0.5sec f11 and the bottom is in camera 9 exposures totalling 0.6 sec f11 both taken with my K-7 back in about 2010. Sorry for the poor formatting of the post it isn’t behaving well with my iPad.
At various times I have utilized this technique as well. I believe I settled on 9 frames as being adequate in most instances.
around 2010 with K-7 f11 9 exposures total time 0.6seconds
