Lumix S5ii accidental nose focus
LumixPete
I have a problem when I use EVF. If you have the touch pad available you can accidentally move the focus point with your nose. I have been trying to go through the settings but with no luck.
My older camera is Lumix G9. In G9 to avoid this I have found this setting: Focus/Release Shutter -> AF/AE Lock = "AF Lock". S5ii is little different so no luck yet.
Is there a place in S5ii where you can lock the focus point in touch pad? You can do it by disabling the touch pad totally but that is not so nice.
