I was given an RTSIII play with and, while almost everything seems to work, there is no display at all in the viewfinder. I have run a test roll through and using Av, changing aperture on each shot , they came out perfectly.
I thought perhaps there might be a custom function as in the RX, which allows you to turn off the viewfinder display, but I can't find any reference to such functions on the RTSIII.
Has anybody come across this problem, or is it simply an electronic fault that most likely can't be fixed?
