Proper useage with Contax Zeiss 28/2.8
Having just bought a 28/2.8 I am flirting with using it for b/w shots. Landscapes, street, people as well as general photography will be considered. My question is that in using a red filter, is it not recommended to use a lens hood as well? Is it necessary? Is it wrong to use a UV filter as well as a red filter?
> My question is that in using a red filter, is it not > recommended to use a lens hood as well? Is it necessary? Is it wrong > to use a UV filter as well as a red filter? > > Just about any 'normal' 55mm filter will cause vinyeting in the corners if > you use a filter AND lens hood. Suggested workaround is to use the 55 > 86 > enlarging ring that is used with metal hoods and a "thin" filter. Using a > UV filter + another filter is probably useless. >
