Hi all -
I'm looking into splashing out on a quick-release system. Currently under consideration is Arca-Swiss, as some of the ball-heads I'm looking at both use this style mount. I currently use an Aria, a RTS II with a W-9 motor drive, and a 300mm f/4.0 lens with a collar.
The Aria isn't a problem... I think the only potential issue might be with the 85 f1.4 which positively dwarfs the body, but I could live with that.
I've been told by one manufacturer of custom plates that there's nothing available for the W-9 motor drive... again, not huge problem. I could either lose the motor drive or keep this on the big lens, but is anyone using a generic Arca-Swiss plate with the W-9 drive?
The real problem is that there doesn't seem to be anything for the 300mm lens since it's got a round foot and there's "no way of putting a plate on it and keeping it from twisting" ... is this true?
Does anyone have any problems using quick-release plates with this or other lenses with round tripod mounts?
Opinions, comments, suggestions would be most appreciated.
