Ring flash for Contax Aria
>Elton
Did you try a contax TLA 360. It is not a ring flash, of course but it works very well for close-up photography even on the camera since the head tilts down a bit
Use a diffuser and experiment with the on-flash compensation.
It beats everthing else I've ever used except for super close work
Dave
Hi, I use a Centon MR20 - it is non-dedicated, inexpensive and works a treat. I also occasionally use my 25 year-old Yashica Medical 100 DX if I don't need the extreme magnification of the Contax bellows unit. Keep an eye on ebay - the Yashica lens is a pearl and still pops up from time to time. Only issue would be replacement lighting units - you'd need to check how often it was used - that's why I rarely use mine! I have also wired up a couple of TLA 20s with heavy diffusers in the past.
Graham
Thanks for the info.
My main reason for looking for a ring type flash is for people shots. I have heard you can get an interesting effect using the macro flash for things other than macro?
I have the 360 and I probably need to play with it a bit more.
Thanks again.
