Settings help
PhilE
I've just bought a Sigma Macro180 to go with my Canon 40D.
I am taking pictures of engraved steel plates measuring about 180cm across and with no flash, usually on an overcast day.
The camera has to be at a distance of about 4.5 feet to get everything in.
Light is very important with this and also to get a positive and not negative image of the engravings.
The engravings are usually flat but from time to time they are curved so I need more depth of field then.
My question is:- what would be the best settings for these shots. ISO, shutter, f stops etc.
Thanks for any help.
Could you post a sample image with your settings...and I might be able to help with a little closer...
Tony C. :z04_cowboy:
Hi Phil,
simple method to aquire more depth of Field, I always regulate f/stops from f/5.6, f8.0 and more, with the trypod I set the lowest ISO for details, then shutter speed....
better if you post a sample :)
Hi Phil,
I have been engraving and also taking my own pictures for about 30 years, up until now I have used 35mm and digital cameras, my latest 40D I have been using a Sigma 28 to 70 with some really good results, I was just wondering what the ideal settings were for this makro.
I will post some pictures shortly...at least you will see what i'm taking and what i'm doing be it wrong or right.:)
I tried posting a picture yesterday morning but I had a message that the administrator had to ok it! Infact I tried twice.
