C
Cwoodhou
I originally started off with CZ 60, 80 and 150 and gradually changed over to the Schneiders. I was careful to make a comparative test of both lenses during each changeover. The 60 Schneider has similar improvements over its CZ cousin as the 150's. Resolution is higher, especially in the outer fields, which for landscape work and fine grain film is a benefit. I actually use the 60 as a standard lens when I'm out in the field or doing wedding group shots. The 80 is typically used for figure work and with extension tubes. Keeping things in perspective, the Schneiders are better, but not so much that the improvement cannot be destroyed by sloppy technique. I quite liked the idea of having them all the same and it has been exciting winning them from ebay sales.
Having said all that I have a suspicion that the 150 Xenotar flares more easily than the CZ. I don't have enough body of evidence to be conclusive, but I have recently had a few cases where I either had fogging during development or flare.
I will run some converter resolution tests next weekend to see if on something like Acros, if it is better to enlarge more or use the 1.4x.
Chris Woodhouse ARPS www.ktphotonics.co.uk
