Cleaning dirt from viewfinder
yukoner
I have an SD14.
How difficult and safe is it to dismantle the assembly that holds the prism and viewfinder in order to remove particles of dirt lodged within.
Anyone know of a tutorial for such a cleaning?
Norm
Viewfinder Assembly/Disassembly Tutorial
Yes, if such a tutorial exists indeed it would!
iMac
I found an generic article on dSLR viewfinder cleaning:
How To...Clean SLR Finder Systems
By Herbert Keppler
Keep your camera clean and intact. SLR eyepieces inevitably get dirty, dusty, and often smudged with fingerprints or the oil from eyelashes. A gunky eyepiece is hard to see through and can make manual focusing difficult. Luckily, eyepieces are easily cleaned.
Unfortunately, dust and other dirt gremlins also accumulate inside the finder system, often when you change lenses, focusing screens, or prisms. A tiny piece of gunk can land on the mirror and then, when the mirror snaps upward, the gunk is transferred to the viewing screen and beyond. Probably, when you're taking pictures, you can ignore a blob, thread, or whatnot in the finder system. But at other times, when you're looking through the finder the glop is downright annoying. And perish the thought that you have dirt or, worse, a fingerprint on the mirror!
What's the best and safest way to clean inside a finder system? Let a professional repair shop do the work. But if you are handy and feel you must do the cleaning yourself, we'll tell you how we do it. Warning! First, an overenthusiastic cleaning or a heavy hand can put more junk into the finder system. And second, mirrors, all of which are front-coated, are very delicate indeed.
Let's start real easy, with the finder eyepiece, and see if that clears up the problem. Light dust or dirt is always best removed by a good-quality, clean paintbrush or a lens-cleaning brush. A microfiber cloth will usually lift off central fingerprints nicely. To clean the finder corners and remove any muck, including fingerprints, stuck to the glass, use a cotton swab moistened with lens cleaner or denatured alcohol (not rubbing alcohol).
When you look through your viewfinder after cleaning, do you still see dirt or other particles that don't belong? They're probably on the underside of the viewing screen. If your camera has a removable focusing screen, now's the time to remove and clean it with a microfiber cloth, as you would a lens?but lay off any lens cleaner (as we'll soon explain). No changeable screen? Remove the lens, turn your camera body upside down (so any dislodged dust or dirt won't fall back into the camera), and give the underside of the focusing screen some blasts from an ear syringe or blower brush.
Dirt still there? You'll have to go after it with a cotton swab. But keep it dry. Alcohol or even lens cleaner can streak the bottom of the plastic focusing screen. If you look through the finder at the same time you wield the cotton swab, you can see just where the swab head is and pinpoint the position of the dust or dirt. But be careful not to get the swab near the mirror!
Dirt still there? Try again. And don't be surprised if the cotton swab leaves cotton fibers. A blast of air will usually get rid of them.
OK, it's mirror time. A swipe with a brush will usually remove most particles. If there are tenacious bits sticking to the mirror and they don't affect the view, we advise you to leave them there. If it's a prominent fingerprint or the like, gently and oh-so lightly rub with a microfiber cloth or a swab moistened with lens-cleaning fluid or alcohol. Do not apply pressure on the mirror or you may damage it or throw it out of alignment.
We won't wish you good luck with your cleaning. Luck may play a small part, but care is far more important!
And when in doubt about cleaning, don't do it!
Hi Steaphany,
Yes, but we need Instructions on how to disassemble & reassemble the SD14 Viewfinder for cleaning purposes.
Perhaps someone who has installed a specialist SD14 focussing screen may enlighten us?
The manufacturers of these specialist focussing screens usually provide installation instructions.
iMac
I've seen those for sale on ebay. The only instructions are to lay the camera body down on the camera's back, take off the lens, and reach inside with tweezers to remove the existing and install the new screen. Seems like it just snaps in place.
I have not seen anything from Sigma regarding this.
I figured a generic viewfinder cleaning method was better than nothing until we can get answers from Sigma directly.
Hi Steaphany,
Katz Eye Focussing Screens provide instructions for fitting their focussing screen to the Sigma SD10. (Google for Katz Eye Optical)
I understand that they are still evaluating the possibility of a focussing screen for the SD14.
Apparently these screens transform the dslr, much better than the AF system especially for low light work. Users laud their praises, much like SD14 users!
I've seen ebay advertising an SD14 complete with Katz Eye focussing screen, so some bright spark has the know how!
iMac
SD14 Viewfinder Assembly/Disassembly Tutorial
I have managed to successfully Remove, Clean & Replace the SD14 Focussing Screen.
For details, please see my post on Cleaning the SD14 Sensor & Viewfinder.
Regards to all,
iMac
