Thank you Niki-Tuan for the simple method of finishing a partially exposed roll. It's important to remember that a covered lens can't slow down the shutter speed (as in TTL metering) and make LT exposures!!
I have just acquired the filter adapter. It did not come with directions, obviously because mounting it is self-evident. Well almost. I aligned the white dots and gently applied pressure left and right but it does not snap in place, it just falls off the camera. I don't want to break the little tabs. Tips, please?
Jan
Jan
