E1 and Megapixels
>"high quality B&W images in 16x20" with a 5mp E-1?? Good luck! You might get a 16x20 print, but it won't be "high quality".
> I did have a Canon with some L lenses and Contax system with CZ lenses and about six months ago i compared scanned images at 100% with some test images the local Olympus dealer let me take with the E 1. At the same magnification the E-1 images were cleaner and crisper. I sent some s&le images to the picture library i subscribe to and they have been accepted. I bought into the sysytem and have absolutely no hesitation in reccomending the E-1. In fact the price at present is being discounted, a sure sign that the new model is on its way. The 5MP is not huge but its all quality, i use Genuine Fractals to boost to a 70 mb file. For me a new body with an increased pixel count would be of little consequence for my useage. The reports i have read of the E 300 are not good, which is a shame. Buy the E-1.
Define "high quality," BJ - If you're talking about looking at a print with a loupe, you're right. But only anal compulisives run around looking at prints with loupes. If you're talking about looking at a print from a proper viewing distance, you most certainly can produce quality 13x19s, and bigger if you have the printer. As I said, I had three images shot with an E-20 printed 30x40 for a show and they were stunning.
>I guess "proper viewing distance" means far enough away so you don't see either the pixelization or the lack of detail/resolution.
Aaah!... Zuiko lenses. Every lens takes the same size filter... Compact lenses covering a wide range of focal lengths. All part of a system... Sounds and awful lot like the OM system. I think I'm sold. Now the only question is, buy now (E-1 or E-300) or wait for the E-3... Hmmm.
For what it's worth, I have been using the E-1 for over a year now and, apart from higher noise levels than I would like at 800 ISO and above, find it more than capable of producing high quality images at up to 13"x19" (the largest size I print).Certainly as high a quality as a scanned 35mm transparency (at 2,700 - 4,000 dpi) can produce IMHO.It really is a case of "horses for courses" I believe - after all, even with the finest grain films you are pushing the limits of 35mm if you expect the ultimate in quality at anything over 12"x8".
Plus the E-1 is , for me, a great handling camera and in my opinion that counts for something too.
I do however find the 11-22mm and 50-200mm lenses capable of better results than the 14-54mm for some reason.Has anyone else come to the same conclusion?
The 11-22 is wonderful. I talked to a Canon Rep that had tested it and he felt it was better than anything Canon or Nikon had built in that mm range. Please don't start a debate over this, I was just giving his opinion and he shall remain nameless. The 50-200 is very sharp but sometimes slow to focus in dim light. I have no problems with the 14-54 and for someone starting out think it covers the best range if you just have one lens. The 50 macro and 300 are very very sharp. F Roberts
The 11-22 is indeed an impressive lens by any standards. BTW, there is a done of E-1 work on my website - www.a-day-in-our-life.com . The Born At Risk gallery is all E-1, as are the christening, and the gay wedding.
Has anyone taken the time to compare sharpness settings on their E-1? I took a range of fixed RAW tripod shots using each sharpnes setting in the range (-3 to +5). Then I compared each at high magnification in Photoshop. Settting -3 was definitely softest. -2 to 0 were slightly harder but indistinguishable from each other. +1 to + 3 were slightly harder again (but also indistinguishable from each other). +4 was softer than +1 to +3!!! And +5 was noticeably the hardest (too much so) of all. I don't have a lot of faith in the integrity of Olympus's sharpening algorithm because it does not seem to give linear results. The +4 setting is a real anomaly. And there seems to be no noticeable difference between some of the other adjacent settings in the range available for user-setting.
