nathantw666
I'm sure you answered some of your own questions already. What t-locks are you referring to? Mine came with little feet and that's it. You can turn them in certain directions to raise or lower the height of the holder. That's really important to get your negative/slides sharp. I usually have mine raised a little higher than the factory default. It improved the scans dramatically.
The wet mount is great, but make sure you don't let any wet mount liquid get under the plastic or you'll be buying a new we mount unit after a year like I did. The plastic start cracking first where the screws are and then everywhere else. Truthfully, it should have been made with something other than plastic.
The 6x6 negative mounts can hold up to 3 negatives/slides per strip.
Hope that helps. Good luck!
Nathan
Nathan
