Sorry about the corruption Osman. I had this happened to me once. One of the files were corrupted and showing me pink and grey lines in the photos. That day I realized, file will get corrupted one way or another unless I protect them somehow. So I started archiving the files that were from long ago, and started archiving them using WinRAR.
WinRAR has a volume system, where you can split the archive into any size files you want. It also has 256-bit AES encryption. It can create recovery volumes, which is kind of a RAID5 for the files, and it can include recovery records too.
For example, I want to archive a 20GB folder in 20 x 1GB rar files, and I want it password protected and encrypted, to have 2 recovery volumes and 10% recovery record. I can do that with WinRAR. It will create 20 x 1GB files, and 2 x 1GB recovery volumes.
Now let's say one of the file got corrupted. I can just open that file and try to repair it. It will use that 10% recovery record and try to fix it. If the error changed the file more than 10%, then it won't be able to, but files usually gets corrupted down to a single bit or byte and that makes the whole file unreadable, so I think 10% is plenty. WinRAR will, in that case, can repair the file and my archive is secure.
And if I lose one or two of the 20 rar files, and if I try to extract files, winrar will see that two files are missing, and it will rebuild those two files from parity data from those recovery files.
This way, so far, I haven't had any corruption issues. I had a few corruption with winrar files, but they were able to repair and fix themselves.
Mentioned it here just in case you want to have these kind of protections within your archives.
