How to remove grains of sand out of the MF barrel
Some grains of sand entered my Carl Zeiss MF lenses during my last trip to the dessert. I hear some 'grinding' noice when turning the MF barrel. How can I clean this myself?
Sander
The first thing you can try is to hold the lens with the front facing down. Then use a business card and slip it into the space under the focus ring. If the sand is not too bad, it will come out on the card, etc. Be careful not to allow the grit to scratch the outside of the lens mount. Move the focus ring to it's othe stop and try again.
If this doesn't do it, you will either have to disassemble the lens or take it in for service. Don't use oil to lube the focus helicoid. Don't use a grease that separates into oil and grease. The helicoid threads must be scrupulously cleaned, then lube it sparingly. Too much may cause or accelerate grease/oil deposits on your diaphragm blades. Hope this is helpful to you.
Where can I find more information about disassembling the lens? I'm not very clumsy, but I would not like to touch the optical part of the lens!
