M7 085 with 28mm 20 ASPH
cmdr
Hello everyone,
I would like to know if any of you are able to use a 28mm M lens with the M7 .085 without the use of an external viewfinder. I have heard some users comment that the 28mm perspective is only slightly wider than the 35mm lines in the M7 .085 viewfinder, and can get a fairly accurate 28mm perspective without the use of an external viewfinder.
Cheers,
Dale
The full viewfinder is almost the 28mm area, but it is no easy to see and IMO it is better an external VF, but be careful with the non parallax correction. Saludos cordiales, Luis
