Help please - anyone who has this lens (or has had in past and knows the answer). I have just purchased one on eek-bay! and all seems well except what I believe to be slightly strange behaviour from the diaphragm.
With the lens off of the camera and set to f2.8, I would not expect to be able to see the aperture blades at all. As they are stopped down electronically, powered by the camera, they should remain fully open when off camera (whatever aperture is set).
However, if the lens is focused at around 1-2 meters or closer, the aperture blades close up slightly, but quite noticeably.
Putting the lens on camera gives the same result and if you press depth of field preview they close down a little more. This is even the case if focused at infinity and the aperture is fully open, press DOF preview and the blades close slightly.
I'm not sure if this is just the way this lens is designed to work, or if it has a fault. If anyone who has this lens could have a look at their own lens and see if it does the same, I would be very grateful.
