Hi
I had time today to "play" again a little bit with my ND. It is kind of difficult, if someone is used by the "automatism" of other DSLRs to find the right sittings now with the ND.
So I would be interested in your experience about the best set-up settings within the ND. I guess all settings there will only affect the Jpeg file and not the RAW files (I hope at least).
There are the settings:
Tone curve
Edge emphasis
W.Bal
Chroma
which are most interesting. If I set tone curve to "standard", images look darker because of the weighting towards the mid-tones. If I put it on "linear", the whole image is brighter, but I guess it will not give sufficinet tone levels in the dark area because of the linear structure of the tone-levels - or did I misinterpret this?
Kent mentioned, that he was most successful with over exposure a little bit (max +1). I can agree only partially to this, in case I have set the tone curve to "standard". But in most cases so far with my snapshots, I prefer to shoot without exposure correction. Maybe it is because of the things I take pictures of. I have to use the ND a lot more before making a real judgement though.
But it would help already to know, who is using the setting "standard" in which situtaion and when "linear" (I am talking so far about Jpeg1, not RAW)
Edge emphasis I have set to "standard". But I did not experiment with it yet...
White balance seems to be in "enabled mode" around 5500K. Unfortunately the wording "auto" with the ND does not mean that the ND switches this automatically to the number it needs, it seems to switch always to 5500K. If I shoot indoor with artificial light, I have to change that in the settings to "preset". Does anybody know whether the ND adjusts within those "enabled" and "preset" mode the Kelvin number according to the light situation, or is it always fixed to 5500K and 2600K?
(I know that I can change the K-numbers manually, but I try to understand how the camera makes the decision and how the automatic works really in different situations to be able to have control over it...)
Chroma I put also always on "standard" so far. I have neither made any test shots in different settings so far with this...
But I can tell you, it is a pleasure to have that camera in my hands. "feeling" and handling are great for an "analogue dinosaurier" like me
I just have to get used to the fact that I have might have to treat the ND more like an analogue camera, with a lot less "auto modes" than other DSLRs. I have to start again to think first, which is good IMO
Have a nice evening and congrats also to Jack for his new ND...
Tone curve
Edge emphasis
W.Bal
Chroma
