old_admin_CI
- Joined
- Mar 8, 2002
- Messages
- 761
Nikon announced yetserday 3 new scanners. The 9000ED is a multiformat scanner (135mm and medium format). Prices are not yet available. Here are the official specs from Nikon:
Nikon SUPER COOLSCAN 9000 ED Specifications
Media Negatives and positives, in color and monochrome
35mm film 1 - 2 strips of 1 - 6 frames; up to 3 frames of 24 x 48mm or 24 x 65mm panorama film can be scanned with optional 120/220 FILM ROTATING HOLDER WITH GLASS FH-869GR
35mm slides 1 - 5 slides with mounts 1.0 - 3.2mm thick, 49 - 50.8mm wide
Medium-format film 4 frames (6 x 4.5), 1 - 3 frames (6 x 6), or 1 - 2 frames (6 x 7, 6 x 8, or 6 x 9)
Medium-format slides Slides with mounts 1.0 - 3.2mm thick can be scanned with optional 120/220 MOUNTED FILM HOLDER FH-869M
16mm film 1 - 3 strips of 1 - 20 frames can be scanned with optional 16mm FILM HOLDER FH-816
Preparates (slide glass for microscope)
1 - 3 prepared slides (26 x 76mm, 0.8 - 2mm thick) can be scanned with optional MEDICAL SLIDE HOLDER FH-8G1
Aperture / Scan range (pixels)
FH-835S 25.4 x 37.5mm / 4,000 x 5,904
FH-835M 37.5 x 25.6mm / 5,905 x 4,032
FH-869S, FH-869G 6 x 4.5: 56.9 x 42.5mm / 8,964 x 6,696
6 x 6: 56.9 x 56.9mm / 8,964 x 8,964
6 x 7: 56.9 x 70.0mm / 8,964 x 11,016
6 x 8: 56.9 x 77.5mm / 8,964 x 12,204
6 x 9: 56.9 x 83.7mm / 8,964 x 13,176
5.9 x 8.2: 56.9 x 83.7mm / 8,964 x 13,176
FH-816 15.0 x 21.48mm / 2,362 x 3,384
FH-8G1 46.02 x 24.0mm / 7,248x 3,780
Scanning system Fixed optical, movable media, parallel single-pass scanning system
Light source R, G, B and Infrared (IR) LEDs; light source with rod disperser and light output slot
Image sensor 10,000-pixel, three-line monochrome linear CCD image sensor
Color separation Performed by RGB LEDs
Optical resolution Up to 4,000 pixels per inch
A/D conversion 16 bits per color
Density range 4.8
Output Full color or greyscale at 8 or 16 bits per channel
Focus Auto and manual; autofocusing point selectable
Interface IEEE 1394
Power requirements 100-240V AC, 50/60Hz
Operating environment
Temperature 10 - 35°C (50 - 95°F)
Relative humidity 20 - 60%
Dimensions 249 x 498.5 x 202 mm (9.8 x 19.6 x 8.0 in.) (W x H x D)
Weight (approx.) 9kg (19.8 lbs)
Scanning time (time to complete preview or scan when no options selected)
35mm slide (with FH-835M)
Preview: 13 seconds
Scan*: 40 seconds
120/220 slide (with FH-869S)
Preview: 38 seconds
Scan*: 185 seconds
*Includes time required to display the scanned image
Density range 4.8
Interface IEEE 1394
Preview: 13 seconds
Scan*: 40 seconds
Preview: 38 seconds
Scan*: 185 seconds
