Noctilux 50mm
B
beowulf
Hi. can anyone tell me if the Noctilux will reduce or eliminate the need for fill-in flash in outdoor events during midday shots?i am referring to photos of people sitting in the shadows of shade trees during full sunshine.or is the need for a Metz inevitable?
M
mikes
Hi Everyone
Does anyone know if I can use standard 60mm B+W filters on the Noctilux? Is there something special about the thread or anything on Leica E60 filters?
I understand that use of filters is not reccomended on this lens - presumably due to vignetting - but I am unhappy about continuously using a lens with such an large and exposed front element without a UV filter.
Mike
H
hektor
Mike, I do not have a Noctilux and cannot speak from personal experience, however I gather that if a filter is to be used with this lens it should be the "thin" variety without a female thread at the front. Have fun. Justin
M
mikes
Thanks Justin. I see B+W list a thin 60mm UV, I will try that.
Mike
M
mikes
Thanks for your comment Joe. Do you mean dangerous to the image quality, or is there some risk of physical damage to the lens?
Mike
pelizza
No, it is dangerous for the lens itself! Leica strictly reccomand do not use any kind of filter with this lens, bracause the front part may be scratched by the filter.
joe
M
mikes
Thanks again Joe. I had heard that Leica do not recommend filters with the Noctilux. I did not realise it was because of the risk of damage.
Mike
