		guyg
Greg,
I have been using Genuine Fractals and have liked it. But I was at a Photoshop workshop by Jim DiVitale and he told us the same tip that was said earlier. For some reason, which the Adobe gurus don't quite understand, the tip of sizing up by 110% is supposed to work just as well, if not better. DiVitale swears by it and says he threw out his Genuine Fractals. I have used both and the 110% sizing trick does seem to work great.
The trick is to go to Image Size and change either Height OR Width under Document Size to 110% and let the other fall where it will. You can make an action out of this and repeat the sizing until you get the size you want. I usually work with 150 - 250 mg files so I don't need to do much resizing (at least up that is) but try it and you'll be happy with the results.
Guy
Guy
