SPP with Mac OSX Lion
toisondor
Has anyone had any problem using SPP with Mac OS 10.7 (Lion)? I've just made the switch and so far, I can open SPP and see my directories of images, but when I try to open a single image, it crashes. I've only tried a couple of times, but the same thing has happened each time.
Jesse
Jesse...I had the same issue...delete the whole SPP program...then re download it and drag it to your desktop...and run from there...
If that does not work try going back to an older version...first then try the newer one...
Good Luck...
Uninstalling and reinstalling did the trick. Along the way, I discovered I was not using the most recent version of SPP (5.01). It seems to be working fine from the Applications folder now.
Jesse
