2x APO ExtenderR
I have a non-ROM version of the 2x APO Extender-R. There seems to be some confusion (at least to me!) as to its compatability with ROM lenses. Does anyone have any ideas? I am only really interested in using it with the 100mm 2.8 and the 80-200mm 4.0, both of mine are the ROM versions. To be fair I have asked Leica in NJ and they told me don't mix ROM with non-ROM. It's just I noticed that some of the lens instructions mention it and some don't. Also non-ROM lenses work with the R8 body, I would have though the principal would be the same. I should probably just take their word for it, but I was curious if anyone had been told different.
Many thanks
Hi Steve - there are two models - the 11236 and the 11237 which is compatible only for the Leicaflex Series - which one is yours?
Best regards
Joseph Low
Joseph,
That's the non-APO version.
Steve is asking about the APO.
Lucien
> [ There is only one way to use a non-ROM extender with a ROM lens. > First mount the extender onto your camera body. This will move away a > lever that will otherwise knock against the ROM contacts if you mount > the extender straight onto the lens. With the extender mounted onto > the R8 body, now mount your ROM lens. You will find that it will mount > and you can also shoot with this combination. > > James Khor ]
>Steve, I have the APO x2 Extender-R, and also the 100mm 2.8 Apo Macro. The >instructions say that it shouldn't be used with the Extender, so I never >have. I've used it successfully with a number of other R lenses, but find >I usually need a tripod because of the loss of stops.
I'll check my instructions on the 100mm 2.8. This was one of the ones I thought was ambiguous. I may have missed it.
It could be time to part with the extender as it isn't giving really giving me much more flexibity and I would hate to risk lens damage.
>The warning was in the booklet that came with my f2.8 100mm APO Macro >lens. I've also seen a slight but noticeable drop in sharpness when using >the Extender with my other lenses. It's acceptable, but if you're an f64 >fanatic it would be a worry.
>Best regards
