Lack of Sharpness with 20D
Matt:
The Picture looks great, can you tell me what the threshold was set at and how does the threshold work
Bob
Bob:
To be perfectly honest with you, I don't actually know how the threshold setting on usm works. Increasing it seems to soften the sharpening effect, but only in the same way that decreasing the 'amount' slider does.
I'm sure someone with deeper technical knowledge of PS will be able to explain the subtle difference, but I can't see it on screen.
Consequently I tend to leave it set to '0' and just use the 'amount' and 'pixels' settings. Works for me.
Obviously the contrast, saturation and sharpening on the above photos are to personal taste, and can be increased if preferred. I find that subtle changes work better though, too much adjustment can look overprocessed and too 'digital'.
Matt & Stephen,
Thanks for the information, all though Stephen I really don't understand what you are saying. Could you please explain a little more?
Thank You
Bob
The USM settings I normally use is 20% and 40 for Radius ... yes, 40 pixels! Here's how they look, with no other adjustments for color or contrast. As a matter of fact, if I reverse these parameters to 40% and 20 Radius, the results look quite similar, and I don't understand why this is so. Perhaps someone can comment on these vastly different USM settings.
Bob,
Let me try and explain a little better.
In basic terms it means that the software needs to see a greater transition (Brightness difference) between compared areas before it applies usm. As Matt mentioned the greater the threshold value the less usm he felt he could see. Have you ever visited http://www.luminous-landscape.com/ this fellow has written some good stuff. If you feel this explaination is still lacking please say, it's alte for me and I'm a little short of words.
SteveH
