Hi, Stephen, that would only be true if you compare a bigger sensor with a smaller one but keep the digital sensor's resolution constant. For instance, comparing the picture taken with a Canon 20D (1.6 crop factor) and a Canon Mark II (1.3 crop factor), the 20D would require a faster shutter speed to keep the same degree of crispness than a Canon Mark II. But that only happens because both sensors are 8MP sensors. If one shoots a bird using the same same lens at the same distance using each camera, the bird's eye, say, would be bigger on the 20D picture, as the 8MPs in the 20D are used to depict just a fraction of the frame the 8MPs of the Mark II does. However, if you take a camera with a full sensor size that has 16MP, say, and another one that has sensor of 10MP and a cropping factor of 1.6, then, the size of the bird's eye (supposing same lens, same distance, etc.) would be the same (supposing the bird's eye is in the picture, of course). In that case, the cropping factor doesn't matter at all. So, what really makes the difference is not the cropping factor, but "the size of the bird's eye" when you look at the picture full size. The new Canon 1Ds Mark II with 16MPs and full 35mm sensore size should require a faster shutter speed than our 20D (if both pictures are taken with the same lens, same distance, same shaking) because if you could crop the 16MP digital sensor, it would still have 10MP, which give us more pixel to cover the same are the 20D did. In other words, the bird's eye will be bigger when a picture is taken with the Canon 1Ds Mark II than when it's taken with a 20D when the digital file is seen full size in your computer.
