O
ou1954
>Posted by Rick Dreher on Saturday, June 14, 2003 - 2:34 am: > >I was prepared to be a no-plastic-Contax snob before relenting and >buying an Aria anyway. > >Wouldn't you know it, mine hit the pavement from a height of about >three feet a couple months after I bought it. Aside from a couple of >small nicks in the prism housing, there's no other mark to be seen. >Based on my earlier experiences, any metal-skinned camera, Contax or >not, would have sustained scrapes to the finish and would probably >have dented as well. The Aria shrugged off my carelessness quite well. > >--Rick
I'm very impressed with the Aria discussion and am interested in changing from my original RTS to a used Aria, primarily because of the weight advantage.
What I have is an original RTS demo model, the ones they made with the gold-plated base for use in dealer demos when the product was introduced. That tends to make it more or less a collectors item since only a few were made. I have two motor drives (one doesn't work just now I think) and a sports grip and a diopter adapter for the viewfinder, -2 I think it is, and a shutter extension cable (which may fit the Aria, don't know for sure).
I am the original owner and it has had one repair, maybe 3-4 years ago, when Kyocera fixed a shutter linkage.
Any idea what I should try to sell it for on eBay or elsewhere?
Any interest out there in this camera? I can supply clear photos if there is any interest.
My lenses are a 50mm Zeiss Planar T* Y/C lens made in Japan, a 25mm Zeiss Distagon T* Y/C lens made in Germany, and a 70-210 Yashica zoom, all of which are fine lenses and it would probably make sense to just keep them.
Don Williams
Don Williams
