> Actually Zeiss is the leader in expertise on resolution. This is > important in many branches of science industry and the military where > the highest level of detail may be needed. They BTW pointed out that > lack of film flatness was one of the largest degraders of resolution. > To get 200 lines/mm one needs a vacuum or other special back, and the > camera is on a heavy tripod and the mirror is up. For digital, the > sensor plane is flat, a great advantage. If one is doing general > artistic or reportage photography, all this may be unimportant. > However, if you want to use a 35mm sensor to capture a group of 200 > people so each of the faces is clear, you need all the resolution..and > contrast you can get. This is where MTF tables are valuable. It > provides a guide to what lenses and at what apertures a lens is likely > to perform to the needs of the project. Asher
