Zeiss C/Y lenses on a digital body - help
Lorraine86
I'm really wanting to be able to use my Zeiss lenses (C/Y mount) on a digital body. It's awfully hard to find any information on this from people who have actually done it. I shoot Nikon digital, but from the small amount of information I have found it seems that it's difficult to do with a Nikon system and you need an adapter which has a glass optic in it to correct the focus, which can affect quality.
I've read people using these lenses on canon digital bodies with an adapter that doesn't have glass in it. I'm about to buy a Canon 1000d to try this with, has anyone on here any experience of this who can give me any advice?
thanks
I've ended up buying a cheap Canon body to have a go with, as I don't want to start spending loads on Canon when I have loads of Nikon!
I have bought a fotodiox adapter. I didn't quite understand the ones with the confirmation chips, as my lenses are all manual focus anyway so I just got the ordinary one. will see how it goes when it arrives!
AF confirm ring is not very expensive. I tried a model without and one with af confirm; When the light is low af confirm is a useful help.
I use Contax c/y lenses via adapter on my Canon 5D MkII and Sony Nex 5N, adapters from the Bay, work great.
C/Y Zeiss lenses on Canon 5DMkII
Hello to ALL, I am new in this forum!
Because I wanted to use mainly my C/Y T* Distagon 3,5/15mm and the C/Y Distagon T* 4/18mm, some little changes had to be made on the rear part of these glasses. Furthermore, the mirror of my Canon 5DMkII needed to be cut-off a little bit, made by an camera/lens repair specialist. Furthermore, the Distagon 2/28mm, the Tessar 2.8/45mm, the Planar 1.4/50mm, and the MUTAR II required some little changes. All other of my C/Y Zeiss glasses work fine, these are the Distagon 2.8/25mm, the Distagon 1.4/35mm, the Planar 1.4/85mm, the Sonnar 2.8/180mm, the Vario-Sonnar 35-70mm, and finally, the Vario-Sonnar 28-85mm!
The cutted mirror disturbs very minor, and has to my knowledge, no influence to the light measurements.
I am using my eleven C/Y Zeiss glasses, and other lenses with C/Y mounts with an adapter perfectly on my SONY A7! Even my C/Y Distagon T* 3,5/15mm and 4/18mm working perfectly with this Sony camera! On my former Canon 5DMkII, I had to cut the mirror for the use of these excellent SWA glasses!
Using on a Sony nex7 various Rollei Zeiss lenses including the 18mm f4 also have the adapter Rollei to Nikon but it does contain a glass element results appear to be excellent however with no af confirmation though - on the Sony cameras there is focus peaking as an aid. I am tempted with a full frame sony A7 or A7r - Regards
