First specs of 300D
old_admin_CI
.... there is nothing yet available on the US-Canon site, but on the German one. The new Canon 300D seems to be almost the same as the 10D. Just minor things are missing. The body for ex&le is not as sturdy as the one of the n10D and the 300D has no costum functions.
But apart of that, the 300D seems to have the same chip (6.3) etc.
Lets see what else we can find over the next 2 days..
The price is agressive with 1099 Euro in Europe (rougly the same in USD). Availablity in September. So after the aggressive announceent of Sony with the F828 for the same price incl. a Zeiss 28-200 lens, we might see a little war this autums and even stronger falling prices.
Great!
sorry for the small picture...
Here are the official specs from the japanese site:
Type I Image Sensor I Recording System I White Balance I Viewfinder I Autofocus I Exposure Control I Shutter I Built-in Flash
External Speedlite I Drive System I LCD Monitor I Playback I Image Protection and Erase I Direct Printing from the Camera I Menus I PictBridges
I Power Sources I Dimensions and Weight I Operating Environment I Battery Charger CB-5LI EF-S18-55mm f/3.5-5.6
Type
Type Digital, single-lens reflex, AF/AE camera with built-in flash
Recording medium Type I and II CF card
Image size 22.7 mm x 15.1 mm
Compatible lenses Canon EF lenses (including EF-S lens)
(35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.)
Lens mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, single-plate CMOS sensor
Pixels Effective pixels: Approx. 6.30 megapixels (3088x2056)
Total pixels Approx. 6.50 megapixels (3152x2068)
Aspect ratio 3:2
Color filter system RGB primary color filter
Low-pass filter Located in front of the image sensor, non-removable
Recording System
Recording format JPEG supporting Design rule for Camera File system (except when Adobe RGB is set) and RAW
Image format JPEG and RAW (12-bit)
File size (1) Large/Fine: Approx. 3.1 MB (3072x2048 pixels)
(2) Large/Normal: Approx. 1.8 MB (3072x2048 pixels)
(3) Medium/Fine: Approx. 1.8 MB (2048x1360 pixels)
(4) Medium/Normal: Approx. 1.2 MB (2048x1360 pixels)
(5) Small/Fine: Approx. 1.4 MB (1536x1024 pixels)
(6) Small/Normal: Approx. 0.9 MB (1536x1024 pixels)
(7) RAW: Approx. 7 MB (3072x2048 pixels)
* Exact file sizes depend on the subject and ISO speed.
File numbering Consecutive numbering, auto reset
Processing parameters Parameters 1 and 2, Adobe RGB, and three sets of custom processing parameters (4 parameters with 5 available settings each) can be set .
Interface USB (Standard/PTP)
Video output (NTSC/PAL)
White Balance
Settings Auto, daylight, shade, cloudy, tungsten bulb, White fluorescent light, flash, custom
Auto white balance Auto white balance with the image sensor
Color temperature compensation White balance bracketing: +/-3 stops in whole-stop increments
Viewfinder
Type Pentamirror, eye-level
Coverage 95% vertically and horizontally with respect to the effective pixels
Magnification 0.8x (-1 diopter with 50mm lens at infinity)
Eye point 21 mm
Dioptric adjustment range -3.0 - +1.0 diopter
Focusing screen Fixed, all-matte screen
Mirror Quick-return half mirror
(Transmission:reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder information AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture value, manual exposure, AE lock, exposure level), flash information (flash ready, red-eye reduction l& on, high-speed sync, FE lock), shots remaining, CF card information
Depth-of-field preview Enabled with depth-of-field preview button
Autofocus
Type TTL-CT-SIR with a CMOS sensor
(TTL secondary image-registration, phase detection)
AF points 7
AF working range EV 0.5-18 (at 20°C/68°F, ISO 100)
Focusing modes One-Shot AF, AI Servo AF, AI Focus AF, Manual focusing (MF)
AF point selection Automatic selection, manual selection
Active AF point indicator Superimposed in viewfinder and indicated on LCD panel
AF-assist beam Stroboscopic flash
Effective range: Approx. 4.0m/13.1ft. at center, approx. 3.5m/11.5ft. off-center
Exposure Control
Metering system TTL full aperture metering with 35-zone SPC
(1) Evaluative metering (linkable to any AF point)
(2) Partial metering (approx. 9% of viewfinder at center)
(3) Centerweighted average metering (Set automatically in manual exposure mode)
Metering range EV 1-20 (at 20°C/68°F with 50mm f/1.4 lens, ISO 100)
Exposure control systems Program AE (Full Auto, Portrait, Landscape, Close- up, Sports, Night Portrait, Flash Off, Program), shutter-priority AE, aperture-priority AE, depth-of- field AE, manual exposure, E-TTL autoflash
ISO speed Basic Zone modes: Automatic
Creative Zone modes Equivalent to ISO 100, 200, 400, 800, 1600
Exposure compensation AEB: +/–2 stops in 1/3-stop increments
Manual +/-2 stops in 1/2- or 1/3-stop increments (can be combined with AEB)
AE lock Auto: Applied when focus is achieved in the One Shot AF mode with evaluative metering.
Manual:Applied with AE lock button
Shutter
Type Electronically-controlled focal-plane shutter
Shutter speeds 1/4000 - 30 sec. (1/3-stop increments), bulb, X-sync at 1/200 sec.
Shutter release Soft-touch electromagnetic release
Self-timer 10-sec. delay
Remote control Compatible with: Remote Switch RS-60E3
Remote Controller RC-5/RC-1
Built-in Flash
Type Auto pop-up E-TTL autoflash (retractable)
Guide No. 13 (ISO 100, meters), 43 (ISO 100, ft.)
Recycling time Approx. 3 sec.
Flash-ready indicator Flash-ready icon lights in viewfinder
Flash coverage 18mm lens angle covered
Flash metering system E-TTL autoflash (linked to all AF points)
External Speedlite
EOS-dedicated Speedlites E-TTL autoflash set with EX-series Speedlites
Drive System
Drive modes Single, continuous, Self-timer/Remote control
Continuous shooting speed Approx. 2.5 fps (at 1/250 sec. or faster speeds)
Max. burst during continuous shooting 4 shots
LCD Monitor
Type TFT color liquid-crystal monitor
Screen size 1.8 inches
Pixels Approx. 118,000
Image coverage Approx. 100% with respect to the effective pixels
Brightness control 5 levels
Playback
Image display format Single image, single image (Info), magnified view (Approx. 1.5x-10x), 9-image index, zoom in, autoplay, image rotation, and jump
Highlight alert In the single image and single image (Info) modes, any overexposed highlight areas with no image infomation will blink.
Protection Single images can be protected or cancelled.
Erase Single image or all images in the CF card can be erased (except protected images).
Compatible printers Canon card photo printers and Bubble Jet printers for direct printing from the camera
Printable images JPEG images
Settings Print quantity, style (image, paper, borders, date), and trimming
PictBridge
Compatible printers PictBridge-compatible printers
Settings Date, printing effects (image optimization), print quantity, trimming, paper size, paper type, and page layout
Menus
Menu categories Shooting menu, Playback menu Setup menu
LCD monitor language 12 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, and Japanese.)
Power Source
Battery One Battery Pack BP-511/BP-512
*AC power can be supplied via the DC coupler.
Battery life (Shots)
Temperature Shooting Conditions
. No Flash 50% Flash Use
At 20°C / 68°F 600 400
At 0°C / 32°F 450 350
*The above figures apply when a fully-charged Battery Pack BP-511/BP-512 is used.
Battery check Automatic
Power saving Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min.
Date/time back-up battery One CR2016 lithium battery
Dimensions (W x H x D) 142 x 99 x 72.9 mm / 5.6 x 3.9 x 2.9 in
Weight 560 g / 19.7 oz (body only)
Operating temperature range 0 - 40°C / 32 - 104°F
Operating humidity range 85% or lower
Compatible batteries Battery Pack BP-511/BP-512
Battery mount 1
Power cord length Approx. 1.8 m / 5.9 ft.
Recharging time Approx. 90 min.
Rated input AC 100-240 V (50/60 Hz)
Rated output DC 8.4 V
Dimensions (W x H x D) 91.0 x 32.3 x 67.0 mm / 3.6 x 1.3 x 2.6 in
Weight 105 g / 3.7 oz (excluding power cord)
Angle of view Diagonal extent: 74°20' - 27°50'
Horizontal extent: 64°30' - 23°20'
Vertical extent: 45°30' - 15°40'
Construction 11 elements in 9 groups
Minimum aperture f/22-36
Magnification and field of view 18mm: 0.1x (248 x 161 mm)
55mm: 0.28x (81 x 54 mm)
Min. focusing distance 0.28 m
Filter size 58mm
Hood EW-60C
Max. diameter x length 69 x 66.2 mm / 2.7 x 2.6 in
Weight 190 g / 6.7 oz
Case LP814
*All the specifications above are based on Canon’s testing standards.
*The camera’s specifications and physical appearance are subject to change without notice.
Copyright © 2003 Canon Inc.
>The downside seems to be that the camera,unlike the 10D is mainly silver=20 >.Why could they not have kept it all black ??
Anyone know what range of these new EF-S lenses will be offered? I assume these are smaller lighter digital-only lenses like those recently announced by Nikon. I did a web search but came up empty.
Hi Stuart,
The rear element of the new lens extends back through the lens mount, and relies upon the extra clearance given by the digital body's smaller mirror. Presumably they've implemented some kind of physical interlock to ensure that the EF-S lenses will only fit the appropriate bodies, or else they've done it electronically by making sure that the older cameras won't fire when an EF-S lens is mounted.
Either way, the goal will be to prevent people from putting the new lens on a full-frame camera and run the risk of knackering their mirrors (and possibly the rear element of the lens) when they fire the first shot.
Also, I see that they have produced a new set of extension tubes to accept the EF-S lenses, so that's another indication that the EF-S glass won't fit on a standard mount.
-= mike =-
