- Joined
 - May 15, 2002
- Messages
 - 3,263
I wrote this in my first review about the RTS III at the very top of this thread. So I post it here again:
"Viewfinder indications appear as white letters and numerals against a lighted blue background. This is great visible in normal daylight situations or at night. But if you are out on very sunny day to make some shots against bright sunlight, you can not see the viewfinder information anymore, because the becomes is becoming so bright.
Sometimes this is even worse, once the camera is 5 years old or older. Then you will have these problems also with normal daylight shootings. The display is basically fading out after a couple of years. But then you should send it for a viewfinder display exchange. After that it is a lot better again. This costs you around 190 Euro In Germany incl. a total check of the camera, but it is definitely worth it. "
So you can improve the visibility on older models (which is ALWAYS getting worse over the years) by the Contax service.
Dirk
Dirk
