>I researched the ideal travel kit for three months, and it's been quite a journey: OM-4, LX, R2, M, XD11, FM3A. You can probably see the pattern: manual focus, manual film advance, changeable lenses, 500± grams. Anyways, I've come full circle back to the Contax SLR. No surprise!
This is Contax Event Week in the US, with all items 10% off. So, I need to make a decision on a new Aria versus the two other Contax SLR contenders: 159MM and 139Q. The RX is most excellent and quiet but, like the RTS versions, too heavy. My planned kit is body, 28mm, 85mm, maybe flash, probably small tripod.
Please comment generally, and also give your opinion on shutter noise, weight, and handling with your favorite lens. Thanks!<
To some degree, comparing a new model to older cameras is like comparing apples to oranges.
I have used my 139Q since purchasing new in the mid 80's and I still love the little camera. I can't compare to the other models since I've never used them.
Obviously, if you choose an older model you are getting something that has been used. If it has been well cared for, you can expect many more years of good service. If not, it may cause you problems you don't want. Just something to keep in mind. (Mine has been well cared for but I'm not parting with it
) Also, there have been technological improvements made since the time of the 139/159. (brighter screens, faster shutters, improved metering, etc.)
Having said that, I think it still comes down to holding each camera and determining which features you must have. Nearly all the shots taken with my 139 are properly exposed and focused. I would like to have spot metering, auto-focus, 1/4000 sec, and so on, but I don't NEED these things.
Determine your true needs and go from that point. Honestly, I thing you'll enjoy any of the models you're considering.
Good luck,
Dave
Things I would like on the 139Q:
Spot meter
Higher shutter speed
Hand grip (FX winder corrected this)
Combined meter/shutter switch
Things I wouldn't change:
Metal construction
Small size/weight
Immediate shutter response
Simple control functions
Complete reliability
